10 Second Club - N54 Edition
Status
Not open for further replies.
Not a powerglide tranny though.
Then this list tells you. The fastest pass is done by motiv, they hold the trap record. Quickest non power glide times are done by cars with the 4L80. If you want stock trans records, once again this chart shows you that. .. Did you scroll to the right and read the details column?
R.G.
668
326
Henderson, NV
E92 335, F10 M5
Spotted at local track
Was running 10.3 @ 13X
Pure Turbo stg2
T4000 transmission
Spoke to owner for a bit, told me it was built by a fella named Cheeseman in Utah
Reactions: Hydra Performance
Fine Tuning
Salt Lake City, Utah
E92 335i N54
Pure Turbo stg2
T4000 transmission
Here are some details on the car-
Owner- Samson McGinnis
Built by Dirty Euro Customs in SLC, UT
DirtyEuro is owned by Richard Cheeseman
Tuned by Troy Nielsen
Mods-
FTI stage 3 TH400
Pure Stage 2’s
PSP 900 FMIC
VS stage 2+
Dual nozzle meth
Running e30 and meth at 21psi we did a 10.6 then cranked it up to 24-25psi with 8-9 degrees advance and ran the 10.353. Ran out of gearing, bouncing off limiter at about the 1000’ mark so now we are going from a 26” to a 28” tire to hopefully pick up about 10mph.
The short term goal is high 9’s and should be attainable with the current setup IMO.
Reactions: R.G.
Congrats!! I'll try to get you on the list shortly. Our site upgrade will kill the tables feature for a few months so it will become a basic text list until then.
Reactions: Slow335is
luchocamp
147
81
f30 335ix / e90 335xi
We have not put rhe car on dyno, probably around 630hp. Most tune done on road 100 to 200kph using dragy.
luchocamp
147
81
What are the full specs of this car? Your sig says 2013 335xi with Speedtech stage 3 but you posted pure stage 2s?
Omar E92 335i specs
FBO
PS2 hf
MHD + JB4 ( @luchocampusano )
E60 Fuel It stg 3 + WMI
record was done using 245 40 18 hoosier drag radials / full weight car.
Status
