Addressing N5x oiling and spun rod bearings (Accusump installed)
Bnks334
524
340
New York
I posted the gist of this in another thread but I am hoping that making a dedicated thread on this topic results in some CONSTRUCTIVE conversation regarding N5x oiling. Are there improvements that can be made other than just blaming oil? Or, are all the street racing bros right that Rotella is life? I think there is more to discuss here, myself...
I recently wiped my rod bearings on track at 115k miles
The above is a short rendering of lap #2 which was the only complete lap I got in for the second session of the day before the car rolled to a stop. Oil peaked 26xf and coolant peaked 220f on the straight. 3 turns later and it just died.
I decided to rebuild the engine myself. this gave me a first-hand look at what went wrong. Here is an album of all the pics I took during this process: https://drive.google.com/open?id=1CtV8pJYwjm-R2lBLrVuWmWSCevqbfJtD . I was a bit too busy with the build itself to worry about documenting key processes, but I can answer to the best of my ability any questions you may have. I was also a bit busy sorting out ECS Tuning's part # mistakes... Those guys really do just blindly throw crap in a box and ship it out.
From what I can tell, it looks like the oil pickup ran dry. The rod bearings literally melted themselves to the crank. The crank journals were not actually all that bad once the babbit material was peeled off. However, the crank took a ton of heat and so did the rods. I was lucky nothing let loose. Rod/journal #1 was the only one that looks like it got a bit of oil and fared a bit better than the rest.
Some notes from the tear-down: intake and exhaust cam ledges looked perfect still. The bottom end was burnt to a crisp. The cylinder walls, valves, pistons, and the main bearings looked OK with the exception of 115K miles of wear and tear. The cylinder head was pretty clean with no sludge (5-6k oil changes with Castrol Edge 0-40 EU). I have done multiple Blackstone analysis in the past and there was never any indication of an issue. In fact, they kept telling me to run my oil longer (7k+ miles). So, lets not go down that road of fuel dilution, thin oil, etc. Oh and yes, 7qts of oil drained out of the pan. In fact, it was about 1/2qt over-filled when this happened. I had just changed the oil the previous weekend and threw in the extra 1/2qt right before the event.
N54 and N55 failures seem to happen pretty frequently at the track. Sometimes there is so much heat generated that the engine throws a rod. In my opinion, the oil pan is pretty poor design for performance work. While the N55 did get a revised windage tray and oil pickup tube, over the outgoing N54, the pan itself is virtually the same for manual cars. The engine sits at an angle and the oil pan sits parallel to the ground. This results in a sump area that has a triangular shape/slant as one edge has to taper to meet the block. The horizontally cut and narrower pickup tube on the N55 seems to be an improvement over the N54 pickup tube for ensuring suction. However, neither pan has a baffle or any kind of provisions for ensuring the pickup stays wet. BMW points this out themselves on page 57 of the "S55 engine PDF." I can see how a situation like being 1/2-1qt low on oil and doing some high rpm pulls and then hard braking could easily run the pickup dry causing bearing wear. Or, if you're coming off a banked straight-away in 5th gear and toss your car into a few steady state turns...
To add to this, people seem to have really bought into the misnomer that N55 is "more reliable" than the N54 (yes the turbos and injectors might be but the bottom end has the same integrity) that they are buying N55's for track duty and thrashing them. It's not going to end well if you think a luxury commuter car can be "raced" on slicks without dropping some money into it. No, 60wt race oil isn't going to help you either. People love to say "LS swap it" but if you dig you'll find that just as many LS motors have had issues with oil starvation at the strip and track. I am not talking about the occasional beginner HPDE. If you want to get serious with the car, you'll need to get serious about oiling.
At autocross, I've logged ~10psi oil pressure under heavy braking. I never really thought much of it since "everybody does it so how can it hurt?" Well... 115K miles later, multiple HPDE days with rcomps, and 20+ autocross events and I am writing this post. I can't blame ll-01 oil, I can't blame dirty oil, and I can't blame "N55 intake camshaft oiling issues." I can only blame myself for ignoring what was a pretty transparent problem. It's even more funny to me now after tearing down the engine and seeing this issue first-hand and then seeing all the M235i owners at the track saying they bought their cars because they are more reliable than E-series N55. "Well BMW races the 235i." NOPE. Only the M235iR got the M2 oil pan...
Here is the M2 pan design (shares the same oiling system with the M3 and M4):
Not only is there a baffle to keep oil from sloshing away from the pickup, there is also a secondary pump which sucks oil from the front of the pan[and turbo drains] and dumps it to the rear (semi-dry system). Even this system is only rated for 1.2g of sustained g-force, per BMW. If only it weren't so expensive of an option... I'd definitely look into retrofitting this setup.
My current solution:
  • A slight oil pan baffle
I took some aluminum sheets and welded a ~1-1.5" wide "L-shaped" piece into the corner of the oil pan surrounding the pick-up tube. I didn't take pictures, unfortunately. I chose this L-shape as it mimics to a lesser extent what BMW did with the M2 oil pan. This is also similar to GM's "batwing" oil pan in the LS swap world.
Before anyone mentions it, I did not like the look of the VAC oil pan baffle. It looks like it would reduce the pick-up area to half of the sump and restrict the return of oil to the pickup in some situations. Turner has made baffles for previous generations, like the s52, which make more sense than this piece, imo.
A baffle alone is not going to cure this problem. It seems obvious that if you need an enclosure like VAC's to keep oil around the pickup that oil is not going to be returning to that trap fast enough either. Meaning, that ~1qt you managed to trap MIGHT last 1 full second before running dry itself... our cars can easily pump 3qts of oil out of the pan in a 2 second long sweeping turn or a 2 second long threshold braking situation like at the end of a drag run. On to the second solution:
  • A 3qt oil accumulator (Accusump)
While an oil pan baffle helps ensure oil doesn't slosh away from the pick-up tube, there are still going to be oiling issues in long sweeping turns. Hence, why BMW put a second pump in the front of the M2 pan. This is where I hope the Accsump will help.
Excellent write-up on Accusump function:
The Accusump is plumbed into the oil return side of the thermostat housing and operated off an electronic valve. In the event that the pickup tube does run dry, the 55psi electronic valve on the Accusump will open at <55psi and allow the accumulated oil to be released. I went with the 55psi valve because the 35psi option just seems like too little too late given that our cars run at significantly higher pressure then that at all times. 35psi might make more sense for a typical car that sees 15psi at idle and 60psi under load. Oil pressure on our cars rises to around 80psi under load.
The electronic valve is always allowing oil to enter the accumulator so oil capacity and pressure inside the accumulator will naturally equalize to the PEAK operating pressure of the vehicle. I have seen the Accusumps accumulated oil pressure sitting at 110psi due to cold starts. This pressure is only allowed to RELEASE when the electronic valve is given the 12v signal from the pressure solenoid (pressure dropped below 55psi). Of course, the pressure bleeds off quickly when the Accusump starts to dumps but it takes several seconds for it to empty and drop below ~40psi. I will try to log the oil dumping to show how long it takes to empty when the car is off.
PSA: don't buy $2/ft nylon braided AN hose off EBAY lol You will be cleaning up oil for weeks when a defect in the line causes it to burst spraying oil EVERYWHERE. And, this lead to tons of other problems like killing my brand new tensioner, pulley, and belt. Don't be cheap and try to get away without replacing your belt after oil gets on it either. Mine shredded a week later and I ended up having to then re-do the brand new front crank seal and drop the oil pan. Nightmare.
I can quote use cases all day to support the effectiveness of the Accusump (lotus uses them), but, I am a skeptic and seeing is believing. Most of the negative things I have seen are user error (like killing the solenoid by allowing it fire 24/7 to dump oil at idle). Maybe I'll eventually buy an electronic pressure gauge so that I can log the Accusump activity. For now, I wired up a simple 12v light into my dash to illuminate when the Accusump activates.
Another benefit of the Accusump is that it can be used to prime the engine prior to starting. It can build 40psi oil pressure even before cranking on a cold start.
https://datazap.me/u/banks334/accus...tart?log=0&data=4-13-16&solo=13&mark=62-32-86
The only drawback? I've hit a DME safety roadblock. The DME is seeing the higher then expected oil pressure prior to starting and throws a CEL. The oil pressure relief valve is then put into a fail-safe mode and the oil pump delivers 100% of its volume to engine (N55 has electronically controlled oil pressure). I don't think it's OK though to daily drive with 110psi oil pressure. This is something I ask the community to help figure out in order to make this feature of the Accusump usable.
Anyone else have thoughts or theories? Any actual "race" teams or engine builders have experience to share? Perhaps the tight bearing clearance results in high bearing temps? Babbit failure due to heat and/or compounding wear from intermittent oiling starvation issues? As seen in the pics above, my bearings literally melted to the crank. I know we've seen all sorts of theories out of the M motor spun bearing issues ranging from oil weight to rod bearing clearances. I've also seen also sorts of speculation about positive displacement oil pumps causing cavitation issues. I don't believe too much in this since the oil pressure sensor would see that type of loss of pressure... it would show in a log. I do think that there is some weight to the rod bearing clearances. I did not measure stock clearance since only rod #1 was measurable, but I did measure during assembly and I landed at right around ~.016" on all rods and mains. Some clearances were a hair wider or tighter. That is pretty tight for 40wt oil spec and close to a 2" diameter crank. KING specs .020"-.025" clearance for "performance" builds. I have also read that tighter than normal tolerances are perfectly fine on an aluminum block. It's hard to separate the facts from the fiction. Lot's of information is just regurgitated from decades old old-school knowledge.
Update:
Here is some autocross comparison data:
https://datazap.me/u/banks334/autocross-accusump
There are 3 logs there, the first log is with the Accusump, the second log is without the Accusump, and the third log is of oil pressure on decel in order to be able to compare actual oil pressure during the runs to what oil pressure is supposed to be.
You can see that oil pressure is dipping down to ~40psi during several turns and rpm is still above 3,000rpms which means oil pressure should be over 60psi. This could potentially indicate that the pick-up is grabbing some air. With the Accusump (60psi electronic valve), oil pressure is above 60psi across the run except in two places toward the end. Oil pressure dips in two places down to about 48psi. The short bursts of acceleration in an autocross probably limits how well the Accusump can re-fill. The results are still much better than the run without the Accusump.
364
716
www.hydraperformance.com
2010 135i 6MT
Fantastic thread btw, sorry to hear about your nasty bottom end failure. How about having a fabricator mod the pan into a batwing design a la C5 Vette oil pan, or something of that ilk? N.B. most of your attached photos are in thumbnail form and are difficult to see well...
Bnks334
524
340
New York
Yes, "batwing" is basically what I did, as seen above. The trap door baffle seems like a good idea until you rationalize that it will be sucked dry almost instantly. VAC design seems pretty poor. It's basically a small box that constricts the pickup tube :/
The N5x version of the "batwing" pan swap would be swapping in the M2 oil pan but it's not affordable like it is in the LS world. Need more people to wreck M2s lol
The thumbnails are supposed to be linked but for some reason this site converts everything to an attachment and now they don't link anymore to the full size pics. I'll have to do full size inserts I guess.
Alex@abrhouston
Oct 25, 2016
146
112
Houston, Texas
www.abrhouston.com
I was thinking about the oil valve the N55 has.
The valve is a restriction- so are you really getting "more volume" (I don't think so) or "more PSI" (I think so)- so on that point- Is it better to have higher oil pressure (less flow/more restriction) or lower oil pressure (high flow/less restriction)......
Looking at the oil valve location in relationship to the pump, it seems to be towards the end of the oil circuit-
N55's for sure have main/crank issues that have yet to be determined. Auto stop/start could be part of it, bad filters, bad oil, too long of intervals, beating on it when cold, etc.etc. are also variables.
We use an accusump on the Ultra 4 we sponsored. Works great when oil pressure is lost!
Reactions: kayzrx82
Bnks334
524
340
New York
When I mentioned increasing oil pressure a bit for higher loads, I was thinking of the concept that a small increase in pressure would increase the amount of flow across the bearings and carry away more heat. Like how when injector duration becomes a fueling restriction you can increase pressure to force more flow through the injector given the same injection window. Slightly higher pressure would force more oil through the passages and form a denser wedge of oil for the rods and crank to ride on.
PLEASE correct me if I am wrong lol This is important stuff.
As for how the pump actually works, that would be pretty important thing to know. I may be completely wrong but I was assuming that raising requested pressure does not use the valve to create a greater "restriction" at all... I think the valve is a diverter valve of sorts which dumps excess pressure to the pan (bypass)... The valve is before the oil pressure sensor and the bearings (the restriction that creates the pressure as read at the oil filter housing). Requesting more pressure post oil pump opens the valve more to allow more oil to flow to the bearings thus increasing pressure.
I see the pressure control valve is on the feed/dirty side of the oil pump. There are then two clean return passages called oil control passages. Not sure how it works really but I was under the impression that the pumps volume is fixed by rpm (and the valves inside to some dwgree) and that the map controlled pressure regulator dumps excess flow to reduce parasitic loss.
I'll post the two pics from the n55 engine PDF I am referencing when I can.
Twisted Tuning
Oct 25, 2016
974
903
New York
www.twistedtuning.com
N54 and N55 Cars
The Oil control valve is at the end of the flow circuit. Its on the clean end and receives oil after it passes through the oil filter. Pump pickup tube to pump, to oil filter. The rest is clean post filter oil.
The control valve is placed at the end to either close off bypass back to pump, or open to reduce pressure. Think of it like a FPR on a fuel rail. You'll have a better understanding of how it works. It also requires a good working oil pressure sensor to be accurate. so i recommend replacing those every so often as well.
Bnks334
524
340
New York
So slightly different...
Same concept though. Not allowing oil to bypass the bearings and go back to the pan raises pressure. Higher pressure should force more oil through the bearings, no? Does the injector restriction analogy apply? BMW seems to close off the bypass, which generates very high oil pressure, in the event of any kind of oil pump related failure. The idea is the same as above, try to force as much oil to run through the bearings as possible if the oil pump isn't working right.
Bnks334
524
340
New York
I see my mistake with the pressure control valve... I overlooked the physical valve on the block (which is the one that is electronically actuated) and I was looking at the "Pressure limiting valve" in the diagrams for the oil pump itself.
Asbjorn
854
602
European, based in China
Z4 N54 DCT
Informative thread!
What I did on my build was similar to what you describe as a "semi-dry" system, but with cooling. I have a pump that draws oil from the front of the pan and dumps it to the rear through an oil cooler mounted on the drivers side. I also have a simple baffle that slows flow between the front and rear of the pan.
I have a switch hidden in the cabin that turns on/off this pump together with another pump that cools my DCT in a similar way. Then all I have to do is flip the switch before I enter a race track.
Bnks334
524
340
New York
Now that is pretty damn slick... What kind of pump is that? seems pretty compact. Has it been durable? I am sure it runs dry quiet a bit. What kind of flow rate does it have? I have read that a typical oiling system pumps 60 liter per minute or so.
The only thing I still like about the Accusump is that it increases the total volume of oil in the system when it dumps. This means that if the issue is poor oil drainage from the head then the Accusump can continue to feed the bearings oil. That extra oil is then returning to the pan to refill the sump even when some of it is pooling up in the head. It then draws the extra oil back in when pressure returns. You aren't actually overfilled for long if at all.
Asbjorn
854
602
Z4 N54 DCT
Yeah so far it has been durable. Done 20 or so half an hour track sessions. I forgot what pump it is, but it looks very similar to the other pump I have for the DCT oil cooler. That pump is a "3 GMP Gear Pump". So I am assuming that means 11 liters per minute.
At the time I was actually considering the accusump solution as well. With this system I got similar functionality, and with a bit of added cooling on top. And unlike just adding an oil cooler to the existing lines, this solution does not interfere with the oil pressure at all. I am not sure if that is important or not, but I like that it doesn't.
Bnks334
524
340
New York
With the exception of a few 328i race cars, the N5x never really being used in Motorsports put the E9x/E8x chassis at a huge disadvantage. BMW really dropped the ball in not really campaigning any cars during this time either. That knowledge and comradery is huge in terms of growing the community like the M235iR has done for the F-series.
People tracking N20's have recorded oil starvation too. N20 pan is very similar (albeit smaller in length) to the N5x pan. The following data shows the consistent drops in oil pressure in every turn over ~1g:
https://f30.bimmerpost.com/forums/showthread.php?t=1023545
And look at the track it was first noted at... Pocono. I think oil not draining from the head is a big factor at that specific track. It's got the longest straight away in the Northeast and of all North America I believe. You spend a long time in 5th gear. It doesn't help that all the oil draining is being forced to be done on one side of the motor too due to the banking (the longest part of the NASCAR oval is the main straight-away for the double infield road-course setup).
People are already racing and building N20s to put deeper/baffled oil pans on them:
https://carbahnautoworks.com/product/n20-engine/
Looking at the S55 engine PDF (I uploaded it in the document section), it looks like pumping oil from the front of the pan to the rear is the way to go. I found a ton of those 3gpm oil pumps on EBAY for <$50. The rest is just the labor to tap the pan and make some fittings. Easy enough. Thanks for sharing that solution!
Reactions: derekgates
gmx
69
29
BMW 1M
Dual pump or dual pickup?
Have you investigated something similar to S54 system with dual pickups, add another one to the front of the pan? Would that work with a customised 2-1 pickup tube and existing pump? I have nfi about lubrication systems. Accusump is cool, but takes real estate. A lot of PPK/aux coolers already in the way.
Bnks334
524
340
New York
I don't think just splitter the pickup works. You end up sucking air a lot. The m2 has a second pump for scavanging oil from the front of the pan and pulling a vacuum on the turbo drain.
gmx
69
29
BMW 1M
Further, I haven't got the oil pumps side by side but it looks like N55 (inc M2) are have electronic pressure control. Don't think it will bolt on to N54, another weakness. Does the M2 use the same engine management as PWG N55?
Bnks334
524
340
New York
Retrofit of the M2 system would be for N55. S55 uses the same electronic control valve.
N54 can do a similar mod to what asbjorn did... pretty cheap/easy to do.
Reactions: Asbjorn
drunkenup
19
135i, 330i
Writing this now at thunderbolt sitting in the media room as my n54 sits with a knocking cylinder 6 and filter of shiny jimmies. Looking to a custom baffle for the rebuild. I'll share my findings, that is if I keep the car
Bnks334
524
340
New York
Sorry to hear... I wasn't ready for mine to pop when it did, but I knew it would happen sooner or later. I already decided I am into this car for the long haul no matter what. Another year or two and it will be a gutted/dedicated track car. Some things to consider:
Think about holding out until you find a decent used motor for sale for a good price. You can swap a motor in an afternoon. You can put new rod bearings in it and whatever else you want to do to the pan before you swap the new motor in. Most affordable and quickest option-- but a gamble on what you get. The gear heads around me convinced me to "do it right" in the end and rebuild.
Sending it out for rebuild will cost more than a used motor, but you get back an essentially brand new motor (Ghassan Automotive). Doing it yourself with upgraded internals will cost similar to sending it out but it takes a lot of dedication and the right tools (and a lot of risk LOL). Lot's of wrong parts got delivered too :/ very frustrating. Took me a little over 2 months working on it a few hours a night. Lot's of time spent at work researching crap. Lot's of weekends not spending time with people because I was in the garage.
