.025mm is tight. Stock bottom end should be closer to .039mm. This is why BMW uses different color bearings and why a set of builders bearings shouldn't be used without machining the crank for a custom fit.
This is the journal that had the bearing fail, this measurement is right before final polish. Based on this I should be good with non oversized coated bearings
What is the status after your rebuild? Piston 5 spun on me, all the rest were dead on. Any failures? I am ready to button it up. My measurements were pretty spot on with yours before my final polish.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
