Dodson Sportsman Plus DCT Clutchbasket Install
So I went and finally installed the Dodson Sportsman Plus clutchbasket that @DMS sent me quite a while back. Had I known how easy it was I would have done it sooner. In my case the transmission is dry so tilting it up was not necessary but I did it anyway in case there was some fluid left over and it is a better angle.
29841
The first thing you have to do is take a photo of your transmission and be sure to pay attention to where the arrow on the cover is pointed. You will need to reinstall this cover in the exact same position. Now remove the cover clip, I used a screw driver and a pick:
29842
29843
29844
29845
Now get some metric bolts from home depot, ace hardware etc and thread them into these holes:
29847
29848
Gently pull on each one a little at a time with a small tug and the cover will slide off:
29849
Now we have the factory clutch basket exposed:
29850
Next, open your the military grade looking crate that Dodson sends you with the pre-assembled clutch basket. The pre-assembled basket is a really nice perk as I've heard trying to mess with the basket itself is a major pain and you know it was done correctly:
29851
Inside you'll have a little tool that helps prevent the cover seal from being pushed backward when reinstalling:
29853
The basket comes with a clip tool so the clutches are pinned so they don't spin when installing/uninstalling:
29854
29876
Put the metal clip into your factory basket:
29855
Hold the lock up:
29856
Now spin the basket a few times and it will disconnect itself inside and can be removed:
29857
Then you'll be staring at this:
29858
29859
Here they are side by side. Dodson on left, stock on right. They look very similar but it's whats on the inside that matters:
29860
29861
29862
Place the stock basket back in the cargo box:
29863
Place the Dodson basket into the transmission, insert the clip, and reinsert the basket:
29864
Install your new seal:
29865
Don't mess with the cover plate on the inside holding the bearing in unless you intend to change that too. Just grab a flat head and pry the seal out:
29866
Then press the new seal back in with your fingers:
29870
29871
Now replace the outer cover seal:
29872
Now place the install tool over the input shaft and slide the cover back on. Be sure the seal doesn't fold itself back outward:
29873
29874
Now reinstall the cover exactly in the same position that you removed it so the arrow is pointing the same direction and pop the clip back in:
29875
You're done! Ship the box with the core back to Dodson. You are also recommended to replace all seals/filters in the process and use new fluid.
DIY Difficulty rating: Caveman
azshantris
151
136
2011 135i N55 DCT GTX1000
Phenomenal display! Been following a few things in these forums for a while and finally decided to log in and say my thanks to the many awesome things I've seen. For now I'm just a boy with a dream but my fbo 135i dct will eventually be a monster too
Welcome and thank you!
There are no ads when you're logged in so there is that benefit also.
