Well folks, here is my final review of the PD Transmission that I bought over a year ago.
Due to my stock transmission going bye bye during tuning by Wedge (not saying that he caused it), I ordered a PD unit.
Initially when it was installed, it ran smoothly like stock. Then, if you have read my other reports about the nightmare that both I and Jason (the owner of PD) went through trying to get warranty work done by Eurotrans in Georgia… you would know that there were some rough periods where I had to send the unit back to Eurotrans because the rear planetary gear set went bad, and also the VB had some worn parts that I replaced with a Sonnax kit…as well as the torque converter. Now you might be tempted to blame this on PD, but it was really Eurotrans’ corruption that caused all these issues. PD did their best to honor the warranty and was in the same spot I was in… dealing with an unresponsive Eurotrans shop.
Anyways, before, during, and after all that foolishness, I was always trying to get the unit to shift properly and smoothly with xHP at any stage…but especially stage 3. And it just never shifted correctly. Symptoms were, lurching, hesitation, jerkiness, and then violent noises when under WOT. No matter what I did the thing just didn’t shift smoothly under WOT.
THE SOLUTION: So, even though all those things were real issues and had to be worked on under warranty, I finally figured out what caused the incorrect shifting behavior the entire time.
It turns out, that the stock EKPM3 controller was not able to supply a stable current to the stage 2 and later on additional stage 3 LPFP. So what ended up happening was the ECU would cut fuel intermittently and that caused the throttle to go apeshit, which confused the TCU and that would cause the shifting anomalies…it was going insane trying to figure out what gear to to into due to the inadequate EKPM3 controller.
So… I recently installed the PM4 Torquebyte LPFP controller configured to run two 450 Wahlbro pumps… and I have been testing xHP in all stages… and now I have been on stage 3xHP for a week now. Shifting has been smooth in normal driving mode even under high power and WOT. Sport mode was problematic for a longer time due to the different shifting parameters and power levels. So… what I did was drive the car in sport mode for the last three days in all situations both conservative and aggressively, AND I also adjusted the torque reduction settings, the max RPM settings… and now the car shifts normally and way smoother than any time in its history with the PD unit.
I want to take this moment to let you know that the Propulsive Dynamics hardware upgrade has not been the issue, the clutches are rock solid, the bushings rock solid… and only that episode with the faulty planetary gear was a problem…that was Eurotrans’ fault for cutting corners…only this was the hiccup.
If Propulsive Dynamics still has any clutch and bushing kits up for sale, I highly recommend you buy one and find a TRUSTWORTHY shop to assembly the upgraded parts. Then just do adaptations reset and the adaptations drive program and then drive for a week on Sport mode and then switch to normal mode and it should be smooth as butter.
I feel bad for Propulsive Dynamics as my problems with the unit were not due to their parts at all but the consequence of a corrupt and arrogant assembly shop in Georgia.
In summary, if you have issues with shifting behavior, whether or not you have an upgraded transmission or stock unit… and you are running stage 2 or stage 3 LPFP setups and you have the stock EKPM2 or 3 controller, you will have to upgrade to the PM4 Torquebyte controller in order to restore consistent fuel pressures to the system so that you TCU doesn’t go insane.
That be all.
That be all.
