Overkill Garage - DIY Single Turbo GTX3584RS
OverkillGarage
14
23
Broken Arrow, OK
07 BMW 335i
Creating my own single turbo setup. A few suspension parts are being replaced in conjunction as well as new fuel system components.
Feel free to follow here or on FB/IG via username OverkillGarage. Constructive criticism always appreciated and encouraged. šŸ‘
4,332
DIY turbo kits FTW! Also how did you get that manifold deck so clean? Mine was pretty good without any real effort but that is clean
Reactions: OverkillGarage
OverkillGarage
14
23
Broken Arrow, OK
07 BMW 335i
Thanks! I think what you are seeing is the head flange mounted to the cyl head. I got it cleaned up, but probably about the same as most. Unfortunately it appears I don't have a picture of the bare head currently for comparison.
OverkillGarage
14
23
Broken Arrow, OK
07 BMW 335i
Iā€™m sure itā€™s just the picture angles, but do you have enough room for the water inlet to the block?
It's pretty tight back there. I worked on the tube routing a bit last night and I think I've got a plan in place. I'll try to get pictures up as I make progress.
very nice o2 placement and wg... keep it up, when it comes time to make the DP try making it 3.5"
Thanks! I believe you had a manifold similar to this at one point right? I'm planning on running 3" turbo back. The price penalty of 3.5" comparatively seemed disproportionate for a small gain in power output.
Arenā€™t the O2 sensors likely going to be getting bad readings since the collector isnā€™t divided and the sensors are angled with the flow stream?
I'll let Omar reply here, but I think they should be fine. I'm planning to use the VTT screw-in adapters to keep the sensors alive.
Reactions: The Convert
