Why would he make them though if the ID is the same as stock? Hopefully, it's larger!
I asked Tony directly, and he sent over these two photos for comparison.
But PSP's are 2"...oh no - overkill! Got all those orders taken care of so you can return to bashing VTT I see.
...this is likely a worse flowing merge than oem...
...it is designed and worse yet put into production with a glaring performance defect...the merger needs immediate redesign.
...Anyone with even an inkling of performance knowledge would understand that this design is absolutely horrendous, to discard such a thing really is telling of your credibility. But hey, a sale is a sale?
OR you can take some advice and just get it revised now, could be a very cool budget option that provides some great performance attributes if you do not overlook the basics.
It doesn't take a flow bench (or a rocket scientist) to understand that two 1.5" tubes merging into a single 2" (or 2.25") tube and THEN tapering to a 2.5" tube is going to pose a restriction over one that is two 1.5" tubes merging into a single 2.5" tube (ie. PSP). These things only takes basic understanding of performance design.
FWIW the OEM outlet tubes are about 1.5" with a semi-reasonable merger into a single 2.4x" tube- the biggest improvement would be in optimizing the merger (not the opposite).
It's more like Pepsi finding out a batch of their own product was made from Horse Piss, and rather than tossing it out they decide to label it and sell it anyway...These guys are not dummies and they both clearly know this was a very poor design...
The only upgrade we see is that it is powder coated black- which is pretty neat. Performance wise a total waste IMO as the OE merger looks much better...
Conclusion: Aftermarket design worse than OEM in current form, or at best a "close to".
You know, I'm not a giant fan of armchair engineering. Never have been. So in light of some of the recent claims about our product performance, in lieu of arguing on the internets we decided to just test the damn things.
Tony had to drop some pistons off over with the fine gentlemen at Rebello Racing, and being as they have a flow bench... well, it just seemed like some testing was the right thing to do. We grabbed a stock outlet we had laying around, and one of the new outlets right out of the bin they get pulled from for shipping. We asked Dave if he would mind some back-to-back flow testing. The guys are Rebello Racing are awesome so they didn't hesitate to stop everything they were doing in order to indulge us.
We didn't do anything fancy, as this isn't a fancy test. We ran all tests at 28" of water, which is standard for most flow bench tests. The flow bench they use is an SF-600, which can flow up to 600 CFM. You can read specs about it to your heart's content at this site: http://www.assurich.com.my/engine-dynamometer-system-superflow-sf-600.htm
We began by installing the stock outlet on the bench using a 2.5" silicone adapter and turned the machine on. Dave does A LOT of flow testing, so his guess that "Range 4" was about right was dead on. Range 4 has a maximum flow of 295 CFM at 28" of water. Results showed it flowed right at 73% (of 295 CFM), so the stock outlet flowed 215.4 CFM.
With no setting changes, we pulled the stock outlet off and put on the VTT aluminum outlet. When turning the machine back on, it flowed 100% at 28" of water -out of range (high) on Range 4 and Range 5. Dave laughed and said "you maxed out my flow bench" as he rarely has to use "Range 6". Dave schooled Tony on the topic after testing and explained how if you have ranges left unused, once you hit above 75% you'll always want to go up to the next range and bring the flow percentage down into a more reasonable range for more accurate readings. Range 6 has a maximum flow of 597 CFM at 28" of water. When Dave turned the machine back on, we could see that the VTT outlet flowed 59% (of 597 CFM), so the VTT outlet flowed 352.2 CFM.
The VTT outlet flows 1.63x as much as the stock outlet. This is a significant difference.
Keep in mind this is a flow bench designed to test NA heads for flow. The CFM reading isn't representative of what it would flow under boost, the purpose of this test was to simply state, outlet A stock when put on a flow bench flows X. Outlet B VTT under the same conditions flows 63% more. This should lay to rest the doubts about if this will perform worse than stock.
Results Recap:
Stock Outlet: 215.35 CFM @ 28" water
VTT Outlet: 352.23 CFM @ 28" water
Difference: VTT outflows by ~63%
Vids:
Video #1: Stock testing
https://youtu.be/V5DDjIwFB9A
Video #2: VTT Outlet testing
https://youtu.be/VA5trZCW9l0
Video #3: Wrap up
https://youtu.be/6PwqwrI6Lu4
Rob, Southwest is cheap. Fly out. We will pick you up at the airport. We'll take you over to VTT, and you can hand pick an outlet from our shipping bins (bring your own stock outlet). Then, while listening to "Born to be Wild" and driving no less than 10 mph over the speed limit (with the windows down), we'll head over to Rebello. After you see this with your own eyes, I will buy you a beer, talk some shit, and send you on your way. Let me know if you're game.
Kind Regards,
Chris
Congrats Chris... in typical VTT fashion you ("and team") found a way to get positive results out by drastically skewing a test in whichever way needed to get a desired result.
Couple things:
1) You do realize you performed this test in reverse airflow? If so the OEM merger would be an absolute disaster in reverse flow.
2) MOST IMPORTANTLY you do realize that the adapters at the compressor housing ends (being much larger) will help static flow on a bench tremendously correct? But you see those adapters are supposed to be at the ENTRY of airflow (from the compressor housing outlet) which is at the HOUSING a much lesser size. This in itself will skew data as you are not putting the housing outlet into the equation, which is the restrictive point. (We will post pics to explain this better in the morning, including the Zage housings as well).
At any rate we appreciate the humor in the reply- but you all should realize these couple things and how they will have a tremendous impact on a bench test. If you want to do an accurate test, on a bench, cut off the adapter ends and ensure airflow is in actual forward flow path as the air will actual move while installed on the vehicle. You both know that your connection point at the compressor housing is NOT 1.4", yet are you leveraging that area for the additional flow. The only way that outlet adapter would be fully leveraged for its flow potential is if you had ported your compressor housings to 1.4" to match it.
Rob
Rob... are you messing with me right now? If you are... you got me. Nice work.
You do realize that a flow bench uses vacuum, not pressure right? This would mean the flow path is the ...same as actual application.
As far as cutting tubes... um...
I've really grown to hate this platform. I think most of it stems from the vendors that supply our aftermarket parts.
Is this real life? This person made post after post telling everyone who would listen the VTT outlet HAD to flow worse than the stock one based on vast knowledge of flow dynamics, (we won't dwell on the fact that he does not even understand how a flow bench operates. Outlined in the post he tried to quickly edit telling the VTT crew they purposely skewed the data by flowing the outlet backward. But yes working for 16 hours makes you all of sudden forget the difference between vacuum, and pressure ). Now that the outlet was put on an actual flow bench, and shows a very real flow improvement over the stock outlet as it would be run on the car. He is scrambling, and trying to convince people that in order to get a valid flow test, the outlets must be cut up, and flowed with the ends removed? Which is it, first you made a giant stink because they outlets were not flowed as they would be run on a car. Turns out you literally had no clue what you were talking about and had to retract that. Now that you had to give up on that stance. You went 180 degrees the other way, and are telling everyone it's obvious flowing the outlets as they are run on the car is going to skew the data. Am I the only one seriously embarrassed by RB's posts? The desperation to discredit a product based purely out of spite and incredibly inaccurate armchair engineering views which were then discredited by actual flow data is so real. That this the person still will not give up on the topic, and simply admit he was wrong should give anyone considering buying any RB product pause. I think Chris said it best. If you are not happy, go do your own flow data. We all know you have no access to a flow bench, and will never do any real testing. You did so much better for yourself when you kept your head down, and just sold turbos. Go away Rob
Of course you do, most idiots cannot admit they are wrong even when given facts proving them wrong. Post up that flow data when you get it. Cheers Bob
