6MT N54 - 7600 RPM Shift
TJ Jrackers
41
15
Whose tune is that running (mhd, cobb etc.)? Looks like the power is dropping off a little after 7k but impressive none the less!
4,331
The title says it's a 6mt which is what it said when I found the video. Also you can see the iDrive is CCC so it doesn't have a dct unless it's a swap or a European variant I don't know about.
Nov 14, 2016
651
261
North Wilkesboro
I feel like, our cars do offer the potential for Supra Status because we have only had a 10 years to get development and upgrades out for our cars but, we are just scratching the surface is what it feels like
Nov 14, 2016
651
261
North Wilkesboro
Stock turbo power falls off hard after 6000rpm yes
Stock turbo with inlets breathe better up top though. Would have to work out on your individual setup.
Upgraded turbos, shift at whatever limiter you have.
If you're running stockers then there is no extra power to be gained after 55-6k rpm
As he mentioned Inlets will help the breathe up top and stay in a higher power level. but, without upgraded turbos they are going to be out of efficiency.
