Loss of engine power
Vetracr
40
16
BMW Z4
I have tracked my car and use track addict to log my lap times. I have been confused by the fact that my early laps are faster than my later ones. You would expect the opposite, i.e., cold brakes and tires. I just found out the reason. BMW reduces engine power as the water and oil temperature go up. For coolant the power reduction starts at 117 degrees C water temp and stops at a 10% reduction in power at 124 degrees C. At that temperature engine will only make 90% of power. The same reduction occurs for oil temperature. Power reduction starts at 148 degrees C oil temp and reduces power until 10% reduction is reached at 157 degrees C. Every new BMW I know runs hotter oil temps than 157 degrees C when on the track. I reach 165 degrees C all the time. That means I'm only running 90% power when I'm at the track. Has anyone else discovered this problem and if so, what have you done about it?
4,331
Besides the obvious hardware upgrades a person could do, I'm pretty sure there is a way to adjust those tables.
Drawing blanks on who where I've read this.
3,597
You should consider installing an M-sport bumper. I think there is significant increase in frontal cooling area. When I get back home, I plan to do some measurements for @Asbjorn who is working on his cooling and air management. We'll make sure we post info.
Vetracr
40
16
BMW Z4
Filippo,
I removed the Setrab oil cooler from the passenger side where the factory oil cooler is placed. I bought the biggest Mishimoto oil cooler that would fit behind the lower center grill and fit between the frame rails. I also added an oil temp gauge to the thermostat housing where the cooled oil returns to the oil filter so I have temp of oil going to bearings. I also added a water temperature gauge to the thermostat water temp input line. I'll let you know results after track event next week. Still doesn't address the computer reduction in power as a function of water and oil temp.
Larry
3,597
You didn't mention which bumper you running?
