Technical MLS or Cutring Head Gasket?
IQraceworks
223
144
Missouri
07' BMW 335i
I'm in the process or ordering all the parts I need to put my motor back together. It should make 575-ish hp at 25psi on a good E40 tune. I've seen a lot of contradicting information on N54 head gaskets.
Maybe the reason I don't see much talk about N54 head gaskets it because it's pretty rare to have problems with them...even the OEM MLS type.
Any reason not to go back to the OEM MLS type head gasket? Or should I spend double the money and go with one of the Athens or SCE Vulcan cutring type head gaskets? Any downside to running the cutring type gasket?
Just trying to educate myself a little bit. Thanks
Reactions: pbondar
586
The trick is to torque down your head studs or oem screws. With the OEM Headbolts many ppl experience headlift around 600whp with a rebuild engine. I had it. The repair manual tells you how to do but it seems that it is not the exact same as it was done in the plant. So MLS will give you the challenge to do it right. Good Luck.
IQraceworks
223
144
Missouri
07' BMW 335i
Thanks for the feedback...but I'm a little confused. The BMW manual tells you the exact way to torque down the bolts. And original OEM gasket was an MLS gasket. If the head and block are clean and flat, you use new oem bolts, and a new MLS gasket.....why would it be a challange to torque them right and get the head to seal correctly? How do you know the way it was done at the plant does not match teh way they tell you to do it in the BMW tech manual?
Do you mean some people just get lazy and don't torque them correctly?
I don't think they mess around with a torque sequence in the factory for the N54. Torquing bolts down individually will always be sub-optimal.
This is a video of the B57 assembly or at least one of the newer engines:
You can see that they just have a robot that perfectly torques them all down at exactly the same time.
Maybe if you were doing this yourself and had time to spare and wanted to improve on the repair manual method you could stagger the torque sequence, so follow the sequence from the manual working outwards but do multiple passes at increasing torque values (20nm, 40nm, 60nm etc). In my mind that would be better as you reduce the pinching effect of one bolt being fully torqued alone.
IQraceworks
223
144
Missouri
07' BMW 335i
Wow....that's pretty cool how they do that. If I had to bet, I'd say that most of the failures people have with using oem bolts is because they don't have the block and deck clean and flat, and they don't follow the BMW process for torquing. But who knows. I guess I will find out.
CalvinNismo
112
163
Elring head gaskets don’t sound like they have the best success rate on N54s. Check out the latest Zero to 60.
