N54 Head Gasket Recommendations
980
Hey boys, In the process of building my N54 at the moment, and was wondering what headgasket to go with. Currently I've acquired Manley turbo tuff rods, JE 9.5.1 pistons, 11mm headstuds from Vac, King main and rod bearings, with the updated bmw crank hub design. Shooting for a 800whp setup, not looking to run it there at all times though maybe a few pulls.
  • Love
980
yeah. Same thing.
Athena is the producer and there are some Resellers with Rebranding. I think i even asked VAC a year ago if it is the same and they said yes.
Oh, im assuming it’s how arp is with Vac as well. Do you know if this would fit with 11mm corner head studs or will I need to modify it a bit
586
i am sure it won´t be an issue. But if the modification will be easy as it is a really soft material.
