Solid Everthing
PC Racing
49
32
BMW 135i
I'm making this post to share the suspension upgrades I'm doing. I'm aware there have been posts on other fourms about this but I haven't seen any about soilid and spherical set ups.
Parts list for the rear:
Akg end links
Ecs sway bar
Akg sphirical lower strut mount
Akg poly upper strut mont
Godspeed toe/upper control arms (spherical)
Polly lower inner
Rouge engineering lower outer (bearing)
Rouge engineering trailing arm bushings (bearing)
Ecs trailing arms
Tuner solid subframe bushings
Turner solid diff bushings
650i finned rear diff
Front parts list:
M3 control arms
Akg spherical inner uppper
Akg spherical inner lower
Akg end links
Ecs sway bar
At this point I have the rear end down and disassembled but I will keep this post updated.
PC Racing
49
32
BMW 135i
Small update of today's progress. I got all the bushings out of the subframe and made a tool to remove the diff from the driveshaft. I have one that was made for the job but it was a few mm to large. On that note if anyone needs any of these tools I'd be happy to rent them out.
4,332
Far as I know the subframe itself is the same. I could be wrong though.
Is it? Also, would be nice to have some kind of repository of of CAD/CNC Program/Drawings for custom tools for things like this, along with the fuel pump removal tool and a few other things.
I want to get into 3D printing and possibly hobbyist milling, so this has been on my mind.
PC Racing
49
32
BMW 135i
Got some things done today. The diff spacer was simple to make since the rear diff mount from Turner moves. The meant the size just had to be within a few mm. I did have to get a larger bolt for the rear diff as the stock one was short buy about half an inch.
Reactions: Relegate
PC Racing
49
32
BMW 135i
