The best bushings and mounts E9X E8X
4,332
I thought I'd make this thread since there's quite a few different options out there, feel free to add suggestions to the list.
Engine:
OEM ~45A
335is ??A PN: 22116773744 & 22116760330
034 Motorsports 50A
Turner 60A Polyurethane
ADE 70A Urethane
Turner 80A Poly
AKG 95A
AKG 75D
Turner Solid Aluminum
Transmission:
034 Motorsport 60A
AKG Red 75D
Vader Solutions Delrin
Rogue Engineering
Differential:
AKG Black 95A
AKG Red 75D
Whiteline
Subframe:
Whiteline
Whiteline Inserts
M3
Reviews:
034 Street Density Motor Mounts
Turner 60A Poly Motor Mounts
Mar 14, 2017
418
346
Minot, ND
2010 135i
I’m using 034 engine and trans mounts and whiteline rear subframe inserts and differential bushings. Haven’t had any issues with the 034 engine mounts yet like a lot of people have. If they fail I’ll probably switch to ADE. And I’m just waiting to buy my new lathe to make aluminum rear end bushings.
4,332
I added whiteline to the list. I also noticed they make some sort of DIY subframe bushing inserts: https://whitelineperformance.com/collections/all/products/kdt918-bushing-kit
Any idea how that works or if its effective or even worth doing?
Mar 14, 2017
418
346
Minot, ND
2010 135i
Jake@MHD
Nov 7, 2016
1,593
2,063
Philly
I have the turner delrin sleeve + aluminum center rear subframe bushings, I think these are probably the best available. Same rigidity as full aluminum, but a much easier install :)
Bmac
78
34
Great White North
They are cheap as heck, would love to hear if the install was easy enough to justify the improvements.
The install is pretty easy. I don't think it made a huge difference but my car was almost stock when I put those in. I have Turner solid aluminum SFB's in the garage but I won't be doing that install myself.
I have the Rogue tranny mounts and M3 diff bushings, and E46 M3 tranny mounts are another popular option.
2,194
Fuck 034 motor mounts. Complete junk. No one should use them. Even new they are junk. See my review on this forum. There should be a disclaimer regarding them.
Solid mounts are the best...depending on your goals of course.
I have the solid turner diff and subframe. Don't get solid diff if you hate diff whine. It doesn't bother me and mine is not bad but I have heard others and it is louder/worse.
1,620
How is NVH with these Turner bushings?
1,497
I've had the whiteline rsfb inserts for the last 50k+ miles. Also have all M3 arms and coilovers. Can definitely say they adequately stiffen the subframe bushings and are worth the time or money unless considering solid bushings like delrin or aluminium. I would not bother with the M3 rsfb.
That said, I'll be switching to solid aluminium next time the rear subframe is out.
Another note from my experience with my car and others I've helped modify over the years is that in THIS chassis, the nvh is derived from differential bushings and engine mounts. Trans and rsfb don't seem to contribute much of anything.
E92 420
134
64
United Kingdom
BMW e92 335i
No mention of powerflex bushing here!
I run solid powerflex black series diff and subframe bushes. They do what they say on the tin. Firmed the car up nicely NVH is most defiantly increased as to be expected with solid mounts, And the solid one piece subframe bushes where an absolute pig to fit!
1,929
664
What's better about the aluminum sfb vs whiteline or other poly Just longevity? Or is their an actual diff
2,194
I would argue aluminum will stay true longer in theory. The cost is not that high in comparison. The new m3s come with solid metal subframe bushings stock. I see no reason to not go metal. Same with diff imo. But you will have whine with diff.
Reactions: Mikejones1208
Mikejones1208
145
115
Savannah, GA
2009 BMW 335i
Wanted to throw in my 2 cents, recently installed a set of condor speedshop subframe and differential solid subframe bushings and love them! For one they are cheap as hell, only 300 bucks for the whole set and are made of uhmw plastic which is a sort of ballistics plastic, doesnt dry rot or crack, and is able to absorb "some" nvh, build quality was fantastic and fitment was spot on! Noticeable improvement in engine response and minimal nvh added
1,497
RSFB feedback::
Just put in the Bimmerworld solid aluminium subframe mounts. Rear end is rock solid. I can't feel any added NVH at all.
They cost less than $300, though the install cost IS higher unless you have an extensive shop at home as they had to be pressed in. Not something you can easily do in your garage IMO.
After driving cars and mine with various setups, I dunno why anyone would bother with anything other than 1. Stock, 2. White line inserts, or 3. Solid aluminium.
Anything else is just an expensive compromise.
