MHD monitoring only showing LFP gauge, nothing else. ETA: I am a noob.
torbearfree
41
10
I am new to MHD.
When I used the monitoring app the gauges pop up but only 1 works, the low pressure fuel pump. The other gauge is there but it is blank.
It does not matter what setting I want to monitor, MHD will only show the low pressure fuel pump gauge.
If I record though, MDH records all of the parameters.
Ideas?
TiAgAu
139
56
08 335i
Data logging options->configure options. Is your layout is set at 1? See my layout is 2x4
torbearfree
41
10
Mine was set to 2 so I changed it to 2x4.
8 gauges show but they are blank.
1and1
65
35
Tally, FL
I'm probably completely wrong here, but your settings are for 2x4 & all are set for boost pressure.
While viewing them as in the screenshot you can click on the second gauge and choose what it will display. Then click on the third & repeat, etc...
That is, click on each gauge in the display to select from the available logging options to display on the dashboard
Reactions: torbearfree
1and1
65
35
Tally, FL
What's really nice is MHD will remember your settings. You can set each of the gauge displays as needed and then rotate through them as needed. A general overview set, a fuel pressure set, a temp set, whatever you need to watch.
