N54 bank 1 runs lean and rich
Templedakota
20
2008 335i. Mostly stock. No maps. No tunes. Catless down pipes and dual cones.
car has given me hell over the last couple weeks. I have done the following to try and get the car running right in the last couple weeks
all 6 new index 12 injectors (they were coded)
All 4 O2 sensors replaced
All 6 spark plugs replaced
All 6 coil packs replaced
Cleaned intake valves
most of the time the car idling fines. Other times it doesn’t. Most of the time the car has barely any power from 750 rpm to 2.5k rpms. Rarely the car will drive will full power throughout the whole rpm ban.
Mis firing in cylinders 1-3.
sometimes I’ll get a 30ff code
Sometimes I’ll get super knocking code for cylinders 1 and 2
car seems to run rich sometimes on bank one and lean other times. I don’t know that much about logs. Maybe someone can help me find out the problem by looking at logs. Any help is much appreciated.
Slowagon54
202
94
Your fuel trims are off. Try to make a propper log please. 3rd gear WOT from 2k to redline an post. Why did you change the downpipes but did not flash the car with a tune? How did you delete the o2 sensors?
Reactions: colo_evo
Templedakota
20
I didn’t delete the o2 sensors. It has all 4 still. Here’s the 3rd gear log. I’m thinking the ecu may have water damage. I drove throw some water the day before I started having issues. I did test mosfets, But they came back fine.
Templedakota
20
Everything I read online says you don’t have to tune the car for downpipes. However, I plan to tune the car later on with Mhd.
Slowagon54
202
94
Man, your log looks very bad. Dont WOT the car anymore before you rule out what is wrong. STFT1 is maxed out. Bad timing corrections and way too much timing added on the motor. You sure the ecu is not touched? I doubt that. Have not seen 11 deg of timing on a stock motor when WOT yet. And if you have DP's how the hell are the o2 sensors not throwing codes? (Well, it is throwing codes...) If you want us to help we need the full story of the car. Are you the first owner? If not, did the car ever perform well since you bought it? What Fuel are you using? How deep was tge water? Hell, you did not drove it thru a river, right? Tell us what happened exactly.
Templedakota
20
Iv owned the car for 5 months now. 89k miles. Drove car throw about 2 feet deep of water. Car drove fine on the way home. (50 more miles). Next day I started having all sorts of issues. Misfires on all cylinders. I was getting faulty injector codes. Haven’t seen injector codes since I replaced injectors.
Sometimes the car throws the down pipe codes and sometimes it doesn’t.
Yesterday when I was driving it, it freaked out. All my dash lights came on and I had a huge loss of power. I restarted the car and was able to drive home.
Templedakota
20
The car preformed perfectly before I started the car after the day I drove throw the 2 ft river. It was flash flooding man.
Templedakota
20
Another thing I have noticed, when I start the car it drives with full power for about a minute. Maybe because the lambda is in open loop? I opened up the ECU and don’t see any water damage or anything. Should I buy Mhd flasher and try putting stock map on car? I honestly don’t have a tune on the car. Everything was stock.
Slowagon54
202
94
I have no idea to be honest. But i doubt the car is stock with such a high timing request thru the whole rpm range... you replaced the injectors and coils, which is good. No DP fix which is bad and throwing codes sooner or later. If you ask me, flash the car with a low octane MHD Stage 1 map and see what it does. BTW check the cooling fan... is it running when you start the car (AC off)? If not, turn the AC on and see if the fan starts to run.
EDIT: Delete the o2 sensors with MHD! It has to be a checkbox to select.
978
Did you code your injectors?
Templedakota
20
After reading this I believe my ECU is bad. This guys is had very similar issue. I’m going to try and update the tune and if not I’m going to get MSD81. https://www.e90post.com/forums/showthread.php?t=1540706
Slowagon54
202
94
Why are you so focused on a bad ECU? 2008 Cars already have a MSD 81... well, late 2008's does. However, lets go the MHD route for now and see what happen.
Templedakota
20
I have MSD80. Car has a build date of 2/2008. MSD80 written on the ECU. Focused on the ECU because for 1 it’s MSD80. Look at these weird codes it through last night.. what else could it be?
Templedakota
20
Holy crap. Ok, keep us posted.
Flashed the ECU and nothing new. Car still acts the same way. First minute the car has full power. After a min, hesitation, misfiring and lack of power. I’m pretty sure I need ECU. Anyone have recommendations for MSD81 swap? I see Colorado has it for $600.
Templedakota
20
I guess I could try linear throttle map? Maybe that would put a bandaid on it?
