Not many manual e60s. You can probably get a manual trans from an N54 e90. It will bolt on the motor easy enough. It's all the other little stuff to make it work that will not be easy.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
