What would you set your boost tables to if you're using a standalone controller (GFBIII)? Would i need to also disable overboost and underboost codes?
MHD only
Disable 30FF error in toggles
Set Boost ceiling to 1.5
Set Load to 220
In MHD + enable custom WGDC control logic and scale the RPM x PSI table
Set 2-3 psi above what you want to run for safety and control the boost with your GFB
Set Load to 220
Set Load to 220
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
