Who has this Crank Seal Protection Plate?
1,620
I just came across this crank seal protection plate. It’s supposed to prevent the serpentine belt from getting sucked into the crank seal if it shreds. Anyone try it?
1,620
Also FYI - the description says “Patent Pending #62751,548”. Most likely they mean U.S. provisional patent application serial number 62/751,548, which is not yet published nor examined, so it is not “patented” as the guy in the video states. Chinese should be able to make these for $1.00
Reactions: kayzrx82
I am sure this will be knocked off in no time. If the vendor just offered it at a fair price no one would bother knocking it off.
Assuming it works of course...
3,593
That's the problem. Then someone in China makes them wh
1/8" plate aluminum scrap, a drill, jig saw, drum sander, and a vise for two 90 degree bends?
F87Source
332
151
Canada
2017 Bmw M2
Just curious if anyone here purchased this plate, it's an intriguing concept albeit over priced imo. I'd like to get this as an ultimate back up plan incase high stresses on the track causes the belt to break, unlikely with good maintenance but it might be possible if an oil leak were to occur.
F87Source
332
151
Canada
2017 Bmw M2
Oh and I'm also curious to know what effect removing those two bolts at the crank "flange" area where the crank seal plate would be bolted into would do, especially since they're also responsible for holding the block together. Would this cause the seal to be compromised because of a slight shift and the block to leak? Because I don't know if there was a specific torque pattern for these bolts, and if there is what would happen if those two bolts were removed.
Slow335is
89
Minneapolis Minnesota
www.youtube.com
Single turbo 335is
I wouldn’t recommend it!
YouTube 📹
Instagram 📸
https://www.instagram.com/slowbmw335is/
Facebook 📲
F87Source
332
151
Canada
2017 Bmw M2
YouTube 📹
Instagram 📸
Facebook 📲
View attachment 36686View attachment 36685View attachment 36688View attachment 36687
Oof that looks bad. How did it break, did the belt break cause the plate to break? Also did it damage the car?
Slow335is
89
www.youtube.com
Single turbo 335is
Bad quality welds and so thin it bent in mail probably it was hitting my pulleys so I removed it. No damage to car thank goodness. Best option new pulleys and belt and call it good! It’s $125 for pulleys and kit online less then the protector!
F87Source
332
151
Canada
2017 Bmw M2
Dang, good thing it didn't cause any damage. Thanks for the fyi!
Illsic_Design
59
27
Sac, Nor-Cal
09 335i
Yeah looks to be because it was rubbing, probably should have made sure it wasn't before driving the car. It has to be thin to fit behind the pulley,
There is another seller on ebay that sells his for $95.\
Edit: hahah he bumped the price to $295 for some reason LMAO. It had been $95 for a whhile, then $150, then back to $95. Now it's 295
F87Source
332
151
Canada
2017 Bmw M2
Gee whiz a knock off that's even more expensive than the original, how does that even work? The tolerances look a bit off though, there's more of a gap in the bottom left of the image vs. too right. So anyone who buys this needs to make sure it's not rubbing against the crank hub.
