2E7C - BSD data bus communications fault
veer90
1,000
774
West Nyack, NY
e90 335i 6MT
Quick writeup on my misadventures dealing with this stupid fault code
A few months ago I got randomly code 2E7C BSD comms fault. Cleared it, went away. It would come back and eventually got worse from intermittent to present all the time. It can be a royal PITA to diagnose especially if it's intermittent at first like my car.
Symptoms (in the order I started noticing them):
  • random 2E9F (oil condition sensor) fault code
  • checking oil level results in no reading, with INACTIVE displayed
  • rough idling, noticeable if you have upgraded motor mounts
  • idle hunt under certain conditions. most noticeable if you clutch in and drop RPMs to idle when moving.
  • oil temperature gauge suddenly reads impossibly high (250+ in the dead of winter with easy driving)
  • faster than normal warm up
  • water pump runs unnessarily. ~3 seconds when locking / unlocking car, full tilt when ignition on / engine off
At this point you're probably thinking the car is possessed and a part out is in order.
Explanation: the BSD or bit serial data bus system links several components together on the N54: alternator, IBS, water pump, oil condition sensor, and DME. Failure of one BSD component takes down communication over the data bus and causes other BSD components to misbehave. Proper diagnosis is only possible when the fault code becomes persistent. At which point the DME fault code memory is checked after unplugging each component, in sequence, with ignition on / engine off. Sequence and explanation courtesy of a BMW tech I spoke with who helped walk me through the process:
1. Ignition on
2. Unplug BSD component in question (I started with the alternator)
3. Clear codes
4. Wait 15 seconds and re-read codes
If code 2E7C persists, then the part unplugged was not faulty. Plug it back in and repeat steps 1-4 for all other BSD components. If all other BSD components are good, then the DME is bad (rare but it happens). According to the tech, most of the time it's a faulty water pump. Another possible culprit is damaged or corroded wiring.
Me being me, I didn't listen and replaced basically everything else first. New oil level sensor... didn't fix it. New alternator... didn't fix it. No IBS (weird how some cars have it and some don't) so didn't need to replace that. Finally replaced water pump this past weekend and the code so far is gone for good. My oil temperatures are back to normal, oil level monitoring works again, and it no longer idles funny.
I don't know enough about water pumps to say for sure what happened, but when I removed it there was coolant pooled in the electrical connector. My guess is the pump housing developed a micro crack and the pump controller said see ya. Very disappointing with just under 40k on an OE continental branded pump.
3,593
In summary, score another integrated electric water pump sucks.
Thanks for the write-up. Very thorough and clear to understand. I sure hope I never have to remember that I read this ...
Reactions: veer90
SJ_1989
368
299
Illinoisssss
2008 E90 335i
This is why I decided to go away from making a custom harness for my drag build that interfaces with the OEM DME....damn CANbus system. It can be done and has been done, but it's expensive. I'd rather put that money toward a standalone and be done with it.
Reactions: Boorda
veer90
1,000
774
West Nyack, NY
e90 335i 6MT
I don't think CANbus has anything to do with this. as far as I know BSD (bit serial data) protocol is bmw specific whereas CANbus is a general protocol for different controllers on a car to communicate with one another.
BrazyN54
27
14
07 335i
Same thing happened to me 2E7C the BSD line would go down and I wouldn't be able to check oil level.
Long story short it was the waterpump,
It stayed on even after the car was shut off for a while, ran very loud and had a lot of current draw put excess load on the alternator.
Reactions: veer90
SJ_1989
368
299
Illinoisssss
2008 E90 335i
It was more of a general comment I guess. Everything is so interconnected on the new cars it causes weird issues/interactions.
Reactions: veer90
HanZel
Netherlands
525i Touring, 2005
Thnx, have the same problem. Changed the oil sensor but no result. aux. waterpump runs very hot doh.
Reactions: veer90
dfpascarella
2006 325i 6spd
I want to verify ISB BSD two wire connection in trunk. It may have been repaired. Can someone verify the wire color positions? Does grey go to grey and the two striped wires together?one of the wires pulled out with pin. May have happened to both so I want to be sure.
setterlee
Hi, I have this issue tmaybe is the water pump...
thanks for sharing this info...!!!
Let me ask you something related with the IBS. My car don’t have it too, even don’t have the blue plug to connect one... your car show any error on the DME that say the IBS is missing?
I can’t understand why some cars don’t have IBS...
veer90
1,000
774
West Nyack, NY
e90 335i 6MT
never had an IBS missing code. might have to do with vehicle order in ncs expert, tells the car what it has and doesn't have.
Tawaz
Guys thanks for all your comments will check mine also for water pump because i cant read oil level and its very annoying
Tawaz
And also guys i dont know if all this applies because mine is N52 ive noticed all this was for N54
djmjakes
1. Ignition on
3. Clear codes
Hi Gents im new here but i have read some of the posts but my problem is i have changed the waterpump and i still have the bus communication error please assist
Enol
I am having the same issue, 2E7C, Data Bus. I have installed new water pump, a new alternator and a new oil condition sensor. When I unplug the oil condition sensor the code went away. I just installed the third new oil condition sensor and as soon as I plug it in the code comes back. Does anybody know anything about this?
Erxk
Could be the wiring connecting to the oil sensor, did you ever figure it out, would appreciate a reply since i just randomly got this 2e7c code after i was washing my car.
Larry Doc
I had the same sporadic symptoms with the oil level “inactive”. I believe the BSD bus is dedicated to water pump, Intelligent Battery Sensor (IBS) and the alternator. I ordered all 3 and while changing the water pump I noticed the electrical connector at the water pump was a bit “crunchy” and the insulation on the 4 conductors was falling apart. i Pulled off the insulation and re-taped everything. this seemed to fix everything….so far. When I change turbos and oil pan gasket I’ll replace the wiring harness. Hope this helps.
