Alturiak
I'm chasing a high WGDC issue with my car and wanted to consult this forum for ideas of what it is that could be contributing to it (or causing it). To start, I have a built N55 with forged internals, 9.5:1 compression, VAC stage 3 CNC ported head, PR coils, and full PI setup running my PS2 turbo. The motor is basically all new and I'm just dialing in the pump gas (91oct here in CA) tune with Justin at Twisted Tuning before moving onto the high powered E85 map.
He has told me many times the WGDC is way high for the boost being made, and I've told him it's always been high since I first got the turbo (99% required to hit 26psi) and because the turbo was new at the time and no one ever mentioned it to me when I was dialing in logs I assumed that was normal and correct for the turbo, since I knew ~25psi was pushing its limits anyways and so pegging the WGDC to hit that boost made sense to me.
Flash forward to now and the car will be going as high as 90% WGDC at 14psi and it's not raising. The shop that built it, Castro Motorsports, has told me several times they pressure checked it and said it was good (I don't know if that's a standard smoke test at 5psi, or if they really checked it at 25psi), so presumably the car doesn't have a boost leak. I recently put on Pure's upgraded heavy duty wastegate actuator and it had no improvement. I'm now in the next couple weeks going to switch over to the new Turbosmart BOV to replace the GFB DV+ and hope that makes an improvement.
I'm hoping the BOV replacement solves it but I wouldn't count on it. I'm just kinda stumped on what else would be causing it? There's no way I can start pushing E85 tunes and really high boost with the way it currently is. Since starting to address this I've replaced the boost solenoid with a Genuine BMW one, both O2 sensors replaced, DP gaskets, hpfp. I was dealing with bad AFRs which I feel I'm still dealing with as well, so any input on that front is appreciated as well.
Here are logs from my dyno day at EAS, with a log from back when I had a JB4 for reference with WGDC. Car put down a best 350whp in 5th and ~315whp in the other 2 attempts in 4th. Really disappointing for a built motor as I'm told it should have been well over 400whp easy for everything that's done to it
