N54 Stock DME Flex Fuel
Chris@Motiv
150
Sav
Theres been huge headway in the last few weeks. I can vouch for that, we have many cars up and running. Its not just a "flash" Jake has to populate 4 bins of logic change, 4 XDF's, and work with Martial on the flashing side to make it all work seamless. We've also been working on the hardware side of things to make sure its adaptable and a nice clean easy install. So when its ready everything will be in stock and ready to ship. There will be a very very large stock.
Tippin
89
49
Cool, great to hear that you guys have made some advancements? Are you able to provide some sort of ETA or is there still no solid eta yet? My car has an ethanol sensor already so i just need to plug some stuff in and go!
tkong
16
Saint Louis
Any hope that this feature will be developed for n55 as well?
LamboLover
238
242
Everything
Yes, but it has only run on an ECU on a bench and has not been attached to a sensor. Simulated values are correct, the ECU appears happy and the bench did not catch fire. You can see that is some while from giving an ETA, but there is a lot more to come.
saw a question with no amswer so ill ask again in case ya missed it ☺...any hopes on n55 guys? post states "n54"
Well they don't typically operate that quickly, but you and I wish they did, right?!
Regarding compatibility, this requires a lot of custom logic work so I don't think its a 'direct fit'. There would certainly require a good bit of porting work, though I suspect a lot of the logic and knowledge will make that a much easier process once they're done with N54. This is only speculation as I really have no clue.
Reactions: slow_henry
slow_henry
42
nj
by n55 in my case i meant pre 2/2012 i knw they had a hard time with pos 3/2012 when mhd came out, does this matter or or is it just a n54-n55 thing regardless of production dates and ecu type
