Map 1 for the ST BEF is overboosting my WG spring psi of 12.5 psi to 17 psi consistently.
I tried manually limiting the boost to 12 psi using the User Settings screen, but as you can see the car still makes 16 psi consistently with that change.
I don't think it's a hardware issue because the boost isn't out of control.
Anyone experience this before, or have any thoughts based on the logs?
Thanks!
Thanks!
