N54 Using VANOS to remove EGR
iminhell1
419
207
I have a hard time believing that the exhaust changing would have little effect. I think you're logging the wrong things if this is the case. You should be able to see a change in WGDC vs RPM. You're either raising exhaust pressure by opening the valve early or reducing it by opening late. There should be a direct relationship to spool vs RPM seen.
And modding for a single turbo is no different that twins. Mass is Mass and Inertia is Inertia. Two or one is irrelevant.
Reactions: Shitrockn54
Sava666
174
36
So EGR in the N54 is done via VANOS, specifically high valve overlap at cruising loads. I always change VANOS values in that range to remove overlap. Anyone else do this? Apparently, it will also prevent intake valves from getting dirty so quickly.
I know there's been discussion about this in other forums which no longer exist, so I thought I'd move the discussion over here. What are your arguments for/against?
Are you talking about Milwaukee's Vanos Thread on n54tech? https://www.n54tech.com/forums/showthread.php?t=21695
Sava666
174
36
How about reducing knock events when changing exhaust table (moving)? True or false?
