New WR: 938whp and 861 wtq @ 35 psi
We saw this car once before: https://bmw.spoolstreet.com/threads/ade-6870-335i-hits-802-30-psi.2580/
And @M3RCLESS and @WedgePerformance are back at it again with some adjustments, this time they produce about 939whp and 861wtq. This car is running the ADE 6870 kit with built motor, full mods list in the link above.
Joe
Probably won't see the graph or the log. It's cropped for a reason. No one says "hey I made a record!" and then fails to crop the actual record. I call bullshit.
Joe
Also, you can clearly see this car made much more than 35psi. The boost tapers up. Use the horizontal scrollbar as a reference. The tune clearly says "NOS" in it. Nitrous? Forget to mention that part?
DennisKing
Nitrous for spool up.
Why are you so salty?
Nitrous? You mean where they started "NX – 125 Shot nitrous kit (DRY)"?
Did you even read the original post? They're targeting 40psi.
Does the record have to be without NOS?
Has 100 shot on car. What difference does it make whether he sprays NOS or meth?
Eric, being a car guy, this can’t be a serious post can it? NOS is considered a “power adder” just like a turbocharger, or super charger. The way NOS works is by breaking down in the combustion chamber, and actually adding oxygen which when given the proper fuel mixture makes a large power increase. That is why its rated in HP, when is the last time a methanol kit was rated by 100 shot, 200 shot, etc. IMHO, this is not impressive. My guess is, they were out of turbo, and wanted to go for 1000WHP before the year ended. They fell short, that’s that. This whole standard now of posting half cut off graphs, and no logs is honestly embarrassing, and smacks of shadiness. You have a record you want to post, show the damn graph, and a log. This is an 800WHP build with a 125 shot on it, nothing more, and it needs to be made known this is NOS record. NOT boost only, big difference.
Erichale77
Yes I'm familiar with NOS and you do have a point if this guy is going for a record. But as we both know higher pulls have been made and not posted so whether he sprayed or not on this pull is irrelevant (to me). But yes power adders shouldn't be counted when going for a record.
Top
