jmctuning
Hello to anyone who can assist me with my Flex Fuel issue
I have setup flex fuel using a specific MHD tune from an experienced tuner (JSR) and a fuel-IT ethanol analyzer which can read over bluetooth plus on a 0-5v signal wire
My setup; The ECA analyzer wire plugged into Harness PIN#16 on the black 26 pin sub
Issue I'm having is #pin16 has 4v coming out of it which is normal based on my testing this car and others. However when I plug my ECA signal wire which currently has 0.28v (pump gas) it doesn't change the PIN16 voltage to the ECA reading but rather keeps the 4v resulting in a E reading of E80 on MHD and my JB4
My fuel-IT app shows E4 which is correct based on pump gas and 0.28v which I measured with a multimeter
My tuner has double checked the tune and seeing as I can see E content in both MHD and JB4 it looks right. But because I have a persistent 4v on PIN16 my E content is skewed
Important to note;
I installed a new DME MSD81 which came from a 135 from 2008 from the USA. I have my old mds80 but is now not coded to my CAS
I have a theory which comes from looking at the wiring diagrams attached in the PDF at the end of my thread
In the USA PIN 16 and PIN17 were used for these functions
16 E USA Signal, fuel tank leak diagnosis pump Diagnostic module for fuel tank leakage
17 E USA Signal, fuel tank leak diagnosis heating Diagnostic module for fuel tank leakage
Could I have a coding issue on this DME which means a conflict between function ????
I did also try plugging in the ECA signal only into the JB4 PIN2 on the DB25 plug and E shows up correct. the analyzer is working as intended
All I can think is at fault is the DME coding is somehow causing the issue
Important to note;
