Vader Solutions N54 Breather System
Nov 5, 2016
615
624
Bay Area
I assume you are leaving the stock pcv system in place to purge the Crank case under vacuum conditions except, your 90 degree bulkhead fitting you have going through the valve cover has no check valve so you are losing vacuum in the crankcase under all idle / decel conditions where its important to have it. No offense you know I already don't like you. But this is a poorly thought out system. It needs some small things to make it work properly
1,052
It looks like he is just copying the Honda/JDM boosted setups where they just vent to atmosphere with massive lines to try and keep crankcase pressures near zero, but never under vacuum.
If the system flows enough volume, it'll work fine, but anyone running it is leaving some hefty engine efficiency on the table by not pulling vacuum on their crankcase at all times.
Bmwfixerguy1
875
292
07 335i MT
I gotta say I kinda agree.. I don't like VTA as a final solution at all..
We might have spoke about this before but what are you pulling a vacuum with? Had anyone tried a standalone crank case vacuum pump?
Nov 5, 2016
615
624
Bay Area
These engines absolutely have multiple issues that can rear their heads when running them at idle with no vacuum on the crank case, smoking is the main one. This system is not well thought out, and I would never run it on an N54 without fixing the issues
1,052
Blow by caused smoking will not occur if the crankcase is adequately vented. Vacuum isn't necessary, only hugely beneficial. As long as the crankcase does not ever go under positive pressure, it's "ok."
We are totally on the same page though with non vacuum pcv offers being a waste of money and not adequate overall.
mt_n54
23
I agree. OP doesn't really understand the N54 PCV system.
Reactions: Rob@RBTurbo
Omar@VaderSolutions
Premium Vendor
Oct 19, 2016
535
409
NY & AZ
vadersolution.com
N54 135i & N54 335i
Hello everyone as much as I think tony likes little boys I'm gonna have to admit that I do need to rework this kit. With that being said , I am working on a new revision. Will consist of check valves for when off boost . Simple fix and I have an idea on how to get this system looking really clean
1,052
The problem with electric pumps is that oil and gas vapors will destroy them. Mechanically driven pumps, on the other hand, require the oil vapor to keep them lubed.
Not sure if there are any products out there that are exception to this rule, but it's what I found when looking for dry dump components.
Bmwfixerguy1
875
292
07 335i MT
If I'm not mistaken I think some are designed as electric vacuum pumps for cc scavenge pumps.. I maybe me wrong but I remeber this somewhere like a summit catalog.
I wish there was a way to use are current vacuum pump
dyezak
1,768
1,518
Plano TX
There are Ford pumps that are on cars (new) with 100k mi waranty's. And Comp Cams makes a performance vacuum pump that moves massive amounts of air for blown big blocks.
Bmwfixerguy1
875
292
07 335i MT
Elaborate.. When you say Ford pumps? Not many companies make their own anything. We may share the same pump from a manufacturer. When you look at a dissected ecoboost it looks almost identical to a dissected n20/6 because they use all the same parts
dyezak
1,768
1,518
Plano TX
I don't know who makes the pump (probably Denso) but Ford uses electric vaccum pumps on some cars.
Erichale77
827
447
Clearwater, FL
07 E92 coupe
Mocal makes great pumps. I'm pretty sure that's what i got on my car. They can run dry without problem too.
